thyNemesis
Thread starter- Joined
- Apr 19, 2013
- 73
I'm in the process of troubleshooting a problem, I have removed the flywheel and trying to do some testing of the stator/battery charge coil. I unplugged the stator, brown/brown-yellow with purple(blue) connector, and connected my meter to the purple(blue) connector, I'm reading around 500ohms. Is this a correct reading???
<snip..snip> from manual...
"Since most stator/battery charge coil test values are near or below 1 ohm"
Any ideas???
I've included a photo on the stator/battery charge coil.
I've checked the ohm value of the purple(blue) connector, 500 ohms.
The way I'm reading the manual, that there are two seperate coils on the stator widings, one for the battery charge circuit and another for the ignition circuit. Am I correct on this?
If I look at the picture, I see two larger yellow coils, 180 degrees apart from each other, is this the battery charge part or the ignition portion?
Any ideas???
