1999 johnson 25 hp , fuel not getting to carbs
tony11905
i bought this motor without fuel pumps ,it has 2 ,im thinking i messed up putting the fuel lines on the new fuel pumps,i do not have a diagram of the hoses of where they are suppose to go ,so if anyone could help ,i would be very happy also this is some more info for you if it helps, this is a 1999 Johnson J25RL3EEM 25 hp Outboard both fuel pumps were replaced but the problem is now there is no fuel getting to the carbs, so the only thing i see is that maybe the fuel lines were not put back in the right place. so what im hoping anyone can one help me with is what hose goes where? please help :confused:
boobie
Re: 1999 johnson 25 hp , fuel not getting to carbs
I don't know the routing of the lines but if the oil mixer tank is still on it, take it off and mix your fuel 50:1. It will save the mtr. Maybe somebody else will chime in with a diagram.
tony11905
ok but what hoses go where?
hidef
Use the attached diagram to help route the hoses. The basic config is fuel connector to port pump port pump out to stbd pump stbd pump out to carbs. Then the two pulse connectors go to the engine. As stated by Boobie remove the oil mixing chamber and tank. Mix 50:1 in your gas tank. I highly suggest you buy the OMC Service Manual for your engine. The small triple are a very nice engine but unfortunately there is very little third party documentation available for them.
Evinrude Fuel System Parts for 1996 35hp E35QLEDC Outboard Motor
