Hello,
I was having issues with water in the top cylinder. I pulled the head and noticed that the previous mech that changed the head gasket did a very poor job on making sure the head was even. I took the head to a shop and used their sandpaper board and made sure the head was even. Torqued the head gasket correctly and it resolved the water issue.
The only problem now is when I pull the bottom plug at idle it won't run on only top cylinder. if i unplug the top, the bottom runs great.
Compression on both cylinders are around 100psi.
