replicaracks
- Joined
- Feb 28, 2009
- 16
I just bought this motor and did and impeller and lower unit oil change, put lower unit back in and had no reverse,I unhooked cable and tried shifting by hand,prop was going in reverse but It was not locked in almost like I could stop it with my hand,I then adding a little pressure by hand trying to force in reverse, and it locked in,but only if I was holding pressure on the shift rod,I then removed the unit again and messed with the shift rod length by unscrewing it several turns,reinstalled,and now I have it way off. Can someone please explain how I set the correct rod length.Detailed instructions would be great as Ive never done this. I am hoping its my rod length and not in the lower unit. I can engage all gears by hand with the unit off the motor.Thanks for any help you can give me.Ben
