TEXAS ROD WORKS
Thread starter- Joined
- May 23, 2008
- 29
I have a johnson 90 ,1999 mod, prob is that when you run it up to 4500 rpm's it will run great for bout 300yds then it will start to act fuel starved, if i pump the bulb it will run fine. I have put 2 diff vro pumps on , changed the vapor sep. commpression on all 4 within 10psi. what next? none of this has fixed the issue. carbs were just serviced ran on portable tank , checked tank on boat i'm lost now!!!!!!
