hydrasport22
Thread starter- Joined
- Apr 4, 2011
- 17
Just before I pull the carbs for a rebuild I thought I would adjust the Idle Jets ( if that is the correct terms).
When I went to screw (allen wrench) them in to check to see where the current base starting point was and I found they were set to 7 1/2 turns out. And they seemed very loose at that point.
On most every carbs I've built it seems these type of screws were 1/2 - 1 1/2 turn out to start then adjust from there.
1999 150 Johnson Ocean Pro.
What say ye matees
Thanks
What say ye matees
Thanks
