1999 Larson Cabrio 254 floor panel / engine compartment cover
Definitive
Hello,
I recently purchased this 1999 Cabrio 254 and found the rear most panel (under the rear bench) is missing, it has been replaced with a thin piece of ply wood which prevents the floor drains from functioning properly.
As I can tell this panel is about 10" wide x 40" long ( i can measure and post photos later if needed)
Also as I can tell this panel "should" be made of fiberglass, although the seller has informed me the panel was origanly plastic.
Either way I am having trouble locating this part for sale, and I am hoping there might be a handy member out there who could cast a mold of the part and ship it to me (id be willing to finance this).
Or any suggestions would be greatly appreciated as well.
thanks
Wild Oats
Re: 1999 Larson Cabrio 254 floor panel / engine compartment cover
I have a '98 254 and the piece you're referring to is plastic, like a UHMW or delrin solid panel so it could be fabricated if it can't be found. Just have to find a shop to cut to shape and radius 1/2" (or 5/8"?) thick UHMW. I'm having problems finding plastic trim pieces myself.
Good luck!
Definitive
ThankYou!Should Be Easier To Make plastic
