1999 merc 115 hp starter prob?
Jasonmint
Having some trouble with this one. Turn the ignition switch Starter doesn't kick in doesn't even try jump across the solenoid starter kicks in then I can use the key to start it. Changed the solenoid still does it. Talked to repair shop they said it could be the switch. So I changed that. Still the same. Good connections on the battery. Could it be the starter itself? Like I said it kicks in every time I jump across the solenoid. Then I can use the key after I jump it once. Any help would be appreciated. Thanks. JD
Jasonmint
Re: 1999 merc 115 hp starter prob?
Any ideas would really be appreciated thanks
Jasonmint
Put on a new starter still doing the same thing. Any one have any other ideas this is a real pain.
