Bakers Creek
Thread starter- Joined
- Jul 19, 2018
- 5
O.K. here we go. Mercruiser 4.3 throttle body injection cool fuel pump making a very loud noise and low pressure around 10-8 psi under load. Engine looses power and will not come up on plane. So I replaced the fuel pump on the cool fuel unit with an Airtex E11004. This pumps max pressure is 125 psi. Now fuel pressure is at 65-75 psi...not good, way too much. My manual calls for 30psi continuous . Removed fuel pressure regulator and verified it is not stuck, reinstalled and verified flow from the regulator while running, still pressure at 65 psi. The mercruiser part number for the fuel pump lists 861156A1. So I sent the Airtex back and purchased a pump that claimed it was a replacement for the 861156A1, Still same issue. .The fuel pump alone is obsolete and it's possible I may have to purchase the complete unit. There's got to be someone out there that supplies a 40 psi cool fuel pump replacement. Engine serial number is 0l082909. Several of the sites claim it is a 86156A1 replacement but I think there are several different fuel pumps that are listed as a 861156A1 but are pressure specific to the engine serial number. ……...Anyone got a match
