DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
Motor is in great shape and has looks to have been maintained.
7-21-13 water/fuel sep filter
Primer stays hards.
new champ plugs at .035 and inline filter above top carb.
Seems to have had 3 CDM (Coils) changed , 2 on one side 1 on other.
Motor is turn key idles perfect
Start accelerating to around 2000 rpm and start to hear miss or something and then and quick stumble sometimes, then onward to 3800rpm-4000rpm it sound rough but starts to go but the motor won't go past that rpm range (3800-4000). Throttle is all the way down and the boat won't plane.
Anything 2000 rpm approx. and under and she's golden.
At first the stumble made me think fuel deliv but the rpm "brick wall" , seems to be spark now. But I will check both.
Checklist and Questions
Check fuel lines and check valves on return fuel lines.
Check crank position sensor for .040in +- .020in (How can I check if the CPS is good at all ?? )
Check TPS (TPI)
IDLE 0.950 ? 0.050 VOLTS
WOT 3.80 ? 0.25 VOLTS
Any way to check the stator with just a multimeter? DVA is home.
Does this motor have a rev limiter or a "Limp Mode"?
What do you guys think it could be? Where should I start my search?
Thanks,
DamianJP
Primer stays hards.
Check TPS (TPI)
Thanks,
DamianJP
