Just got a Portabote with 99 Nissan NS5B that hasn't been used in years and only had about 30-40 hrs on it. It looks new. Was run dry then the spark plug removed and a little 2 cycle oil put in. Everything under the cover looks brand new. There are small dabs of grease on any moving parts.
The motor starts in 3-4 pulls and seems to run fine at first. After a few minutes putting around at half throttle...it bogs and dies. Taking it out of gear doesn't stop it from dying. This is my first outboard, so I don't really know where to start. My guess is a fuel/carb issue. It seems to run perfectly for a few minutes..then bogs and dies. If I let it sit for a few and try again, it will run again for a few minutes. Once it dies, it typically won't run until I let it sit for a bit. I'm running 32:1 ratio of two cycle oil with new super unleaded vs the 50:1 in the manual, since it has been sitting.
Any suggestions or links to carb diagram would be greatly appreciated for this outboard newbie
. Fire away with questions if I haven't provided enough info.
