Cliffteeray
- Joined
- Jan 7, 2012
- 9
I am in the final landing pattern of purchasing a 1999 Grady-white 272 sailfish with twin 200 OX66's with 350 hours. As this is my first foray into the saltwater relm any feedback or suggestions would be greatly appreciated (other than this seems to be a bottomless money pit, but i guess we can't take it with us).
The boat is in excellent shape. the compression tests came back: 1) 125, 119, 125, 121, 112, 121 and 2) 124, 124, 119, 126, 123, 124. During the 1st sea-trail, we got 10 feet from the dock and the port side alarm went off. Pulling the head off revealed salt build-up that was clogging the water circulation. The Yamaha certified mechanic cleaned out both engines and replaced the thermostats. Afterwhich, we tried it again and the starboard engine was "peeping" weakly, he blew it out with air and they both ran at 5100 WOT (one engine was at 5000 and the other at 5200, reaching 39mpg).
It is thought that there might be some additional salt build-up at the last point the water exists the engine (by the battery sending unit - or something like that) Also, the props also need a good greasing.
The boat weights 5500 dry and had a full tank of gas, 205 gallons. I am being told that the recommended rpm is between 5,000 and 6,000; it has 17" props which is the reason why it reached the lower end of the range. (it was thought that the smaller props would help with the mpg).
All in all, it seems that the seller could have preformed a better maintaince schedule. The mechanic tells me that these are normal reoccuring issues.
Any thoughts? Considering the weight of the boat and age of the engines, is this combination going to kill me on gas and oil?
Thanks
Thanks
