1999 Suzuki(Evinrude) DF70 Tilt and Trim won't go down
99yam40
Re: 1999 Suzuki(Evinrude) DF70 Tilt and Trim won't go down
Yes you can.
Does the relay make any noise when hitting the down button?
99yam40
Yes I believe that is the T&T relay
So if it clicks then the switch is working, but relay is not making contact with either the + or the -.
A volt meter would come in handy for troubleshooting
Ldavidgrover
Replace both and save yourself further trouble
bobcatlou
A quick followup: I switched the green and blue wires and the "Up" switch now caused the T&T to lower the engine. Hopefully I can assume that the down relay is defective. I did notice that when the engine started to go down that made some sputtering or bubbling noise. Is this some air in the line, and how do I fix it?
Ldavidgrover
Trim it all the way up and open the fill screw. Add fluid if needed
