fixmyevinrude
Thread starter- Joined
- Sep 18, 2008
- 205
1994 Evinrude 200 hp 90 degree looper.
1) Engine started knocking and loosing power
2) No compression middle cylinder port side
3) Pulled head and found needle bearings embedded in top of piston and head, also deep score where piston apparently drug needle bearing from port to top of cylinder
4) Am in process of removing powerhead. Should be off in a few days. I am labeling and photographing everything.
Never have rebuilt a motor before but feel confident that I can do it. I am a tool and die maker and am comfortable with close tolerances.
Since I don't have motor apart yet I don"t know if bearings are from crank or wrist pin. I know I will need a new sleeve.
Assuming the crank is OK I would like to replace one piston, put all new rings and bearings in, replace the bad sleeve and have it bored and honed and have the five remaining cylinders honed assuming they measure out OK
Would like any recommendations, tips, critiques on the above problem and plan to fix it.
Can anyone recommend a shop in the St. Louis, MO area to do the machine work?
