2.3 OMC cobra
joshn569
1989 bayliner with 2.3 cobra
Bad engine...
can i rip the motor out a ford ranger and convert all the marine parts to it and run that?
or.....
What other engine(s) will bolt in place and work? is a v8 conversion pricey?
ifallsguy
Re: 2.3 OMC cobra
my understanding is the short block (block, crank, pistons, oil pumtp, timing belt and pullies ) are the same. Everything else is marine (intake and exhaust manifolds, carb, starter, distributor, alternator, etc. You should be able to do it.
joshn569
Re: 2.3 OMC cobra
cylinder head is the same too?
my boat had the cylinder taken off for a head gasket then sat apart out side for 3 years without being covered up. So i have everything but the head is seized up and cylinder walls rusty ect...
if I could pop a ford ranger or mustang motor in that would be super..... years that would be compatible....???
