Well first off I bought this boat late last year with a few issues thinking it would be an easy fix well one thing lead to another, I rebuilt the carb, new plugs, plug wires, coil and points just as a preventative maint. thing and then when i took it out late last year it was overheating so i went home put a new outdrive water pump in it and checked the upper pump and put a new thermostat in it, ran it on the muffs and it was fine. Well i have been doing other things too it this year and i finally took it out today and it ran great we checked the timing it was right at 10 deg BTDC and the points are brand new, we motored around for pry a good 30 mins and the temp started to creap up on it. So i shut it off sat for a while to to enjoy the weather and we motored around for another 20 mins and the temp went to around 230 or so, and wouldn't come down. Could my of outdrive pump went out already? Could there be sediment in the block if so how do you get it out? Also it didn't want to shift into reverse in the lake it ground really slow like it wanted to fall in, but just wouldn't do it or it poped out once it was in, on the muffs it was fine. In FWD it would fall in just fine in the water and out on the muffs. Does it just need to be adjusted or is there bigger problems?
