2.5L Head is toast now what?
chiefalen
Ok coupler went in the boat in my signature. Replaced it.
Dip the boat in the water get about a mile, water pump shaft goes. Replaced it.
Yesterday get about 5 miles head went.
Dejected does not even come close to the word.
Ok where i get a head?
Can't i use a auto head? What will fit?
1980 Citation?
Oh wonderful, all knowing, masters of the boating realm help a down and out wanna be boater.
Casting numbers off the head are,2778962 120 86.
Part # current-986767. Old # 982241. Is there a way to cross reference to a auto head?
Does someone know of a used one? Maybe fresh water?
Thank you all.
JustJason
Re: 2.5L Head is toast now what?
what did you do to the head? have a massive overheat and warp it? where you lugging the motor and tuliping the valves?
Can ya just bring the head to a machine shop?
auto heads will work. but you gotta go way back in the books.
your gonna find it in 60-70's chevy II's, and other gm products from that era
THE BEEF
I used a place called TRI STATE Heads . I found them on the net.
They repaired a Kohler OHV head on my tractor. Done a great job.
There web pictures shows some pretty screwed up heads (lots of cracks)
They weld them up and refinish them.
Hope this helps
BEEF
chiefalen
Discovered behind the t-stat housing in the head a hole into the valve pushrod hole.
Aint gonna fix that. Never saw that before.
Gotta get a used one.
Can't i use a auto head? What will fit? Is there a way to cross reference to a auto head?
Nope,.... No auto heads will fit.....
Another head from a 2.5l Boat motor will,...
Mercruiser,.. OMC,... Volvo,... Any of them....
A 3.0l head will bolt on,..
But I don't know if the Valves will hit the block due to the tiny bore of the 2.5l...
chiefalen
Ebasic power has a 3.0 they say will fit a 3.0 and a 2.5.
But all the numbers i get are they are 2 different heads.
I need a 2.5 head fresh water used.
Anyone ever see that problem before.
And a good thing i didn't break on bolt.
Took off the manifold no problem. Still good.
JustJason
Hmmm.....
On the heads...
I say yes... Bondo says no.
But.... do some homework and research Chevrolet 153 engines from 1960 to 1970 found primarily in the nova's and chevy II's. I'm almost 99% sure it's the same head.
As far as what ebasicpower lists.... I dunno about that
the 2.5 is 153 cubes
the 3.0 is 181
The heads are going to have different combustion chambers
I'd see what I could do about finding a 2.5 head instead of mickey mousin around with whata got.
Not sure about your issue... can you post a pic or 2 about what you got for this "hole"?
Ayuh,.... Of Course they're Different Heads,.... They're different Motors....
You asked what would Fit,+ Run,.....??
There are Various different Heads,... Some have different Ports,.. Some different Chamber Volumes,.. Some with different Sized Valves,...
But,....
They'll All bolt on,+ Run......
79Glastron
If you install a 3.0 head and use the 2.5 manifold, you'll have poor port matching. If cash isn't a problem, get a rebuilt 3.0 and throw it in.
chiefalen
If cash wasn't a problem ha i would have a brand new boat.
chiefalen
Local guy used boat parts, had my 2.5 head. Good shape too. He threw in the bolts.
He has everything great price also. Whole motors.
Anyway leak down test on head is a.o.k.
Waiting for gaskets.
Third times the charm they say.
Busy painting the head and the manifold, over and over ha.
Uraijit
Banned
Man, and I thought I had rotten luck!
Hope this fixes all of your problems, and that this boat FINALLY gives you years of worry-free service. You deserve it after all the things you've fixed on that puppy.
What did you learn?
Repeat after me: "I will never buy OMC. I will NEVER buy OMC. Free is too expensive for OMC. I will never buy OMC"
HT32BSX115
What did you learn?
A LOT of of us are in that club!! It's even worse if you buy a OMC 460:eek:!!
chiefalen
This time was a engine problem. No more old pos for me. My mantra from now on.
chiefalen
Ok new to me used head on.
Everything is a.o.k.
Running good everything is good.
Changed oil.
I should buy stock in a oil company .
Whats gonna happen next?
Nice tomorrow going out.
Bond-o ask me again what P.O.S means. O.M.C.
