2 and 3 pin anchor light
stickerhard
I just bought a flat bottom boat and it has attwood sockets for the bow and anchor light. It has a 2 pin socket on the front and a 3 pin socket on the stern light.Does any one know how the 3 pin works compared to the 2 pin? My other boat had a 2 pin and would like to have it so I could switch lights from one to another. Thanks
Silvertip
Re: 2 and 3 pin anchor light
You can't stuff a three pin mast into a two pin base, or a two pin mast into a three pin socket unless the pin layout accommodates the two. You likely need to replace one or the other. Have you checked the Atwood web site to see about the three pin base? Pull the base and see if there are actually three wires connected.
stickerhard
I will have to take it out and see when it quits raining I thought some one might know if it is wired differently is all. Thanks
you can put a 3 pin light in a 2 pin socket but it will not work as the 2 pins being used will only work the deck light (little light behind the main light) You will either have to change the base or get a 2 pin light
