Re: 2 batteries necessary?
The answer to your question involves your purchase: 1) Bowrider or 2) Cuddy? If you have a bow rider that says buzzing around, skiiing, towing water toys etc. Cuddy says perhaps periodic overnights on board. The two boats require totally different approaches. A bow rider does not need a second battery unless you are inclined to add a gazillion watt stereo or other high current draw accessories. If you don't have any of that stuff but are still wondering about the possibility of a dead battery, carry a jump start unit. Problem solved. To add to that, know the proper starting procedure and keep the engine tuned so you don't have to kill a battery trying to get it started. If you end up with a cuddy, you will have late night lighting and other stuff to power so a large deep cycle battery is certainly suggested. Use a battery switch or ACR (auto charge relay) to isolate the two batteries while allowing both to charge when running. If you are unfamiliar with battery switches or electrically challenged, then an ACR is probably best for you.
