2 cycle gas mixtures and thier effects on running
Newyota
Recently purchased a 1988 9.9 johnson.Sticker on motor said to run 100:1, which the two previous owners did.I read on this site that Johnson and Evinrude later changed thier mind about this mixture said to run 50:1 which is what I thought should be run on this.My question is did this damage the engine in any way and how will this efffect engine performance.I am mixing 50:1 now and am going to take it for a test soon.
JB
Re: 2 cycle gas mixtures and thier effects on running
Running on the 100:1 mix was not a problem, Newyota. I know of no damage caused by it.
The problem that caused OMC to retreat to 50:1 occurred in long term storage. 100:1 didn't leave enough of a film of oil on internal parts like needle bearings. Some corrosion occurred.
Your engine should be just fine running (and stored) with 50:1 fuel mix. :)
boobie
As long as the PO's fogged the mtr when stored you should have no probs.
