2 cycle motor oil poured in each cylinfer at spark plug hole how long to burn oil out
Silvertip
Re: 2 cycle motor oil poured in each cylinfer at spark plug hole how long to burn oil
Perhaps you might explain just what it is you are trying to accomplish?
Outsider
If it's a two-cycle motor, just run it with your normal mix. If it's a four banger, run it with straight fuel. Might want to check your plugs after the smoke clears (pun intended) ... ;)
