2" Hole Cover for my Dash/Helm- What to use?
OllieC
This weekend I replaced the existing 05 Clarion receiver with a wired helm remote on the Sara Belle. (What a project) The new remote for the new Sony was bigger so I had to install it in a different location.
So now I have a 2"-2.5" hole on my dash. What can I use to cover it, that kinda' looks like it belongs there? Keep in mind, that I am the type who measures 5 times and still screws up a cut. If there is anything factory looking that I can put in its place, like a plate, or grommet of some kind, I would prefer that.
Thanks,
Ollie
UncleWillie
Re: 2" Hole Cover for my Dash/Helm- What to use?
Whatever problem you have; Someone has already had it!
Something like THIS?
The manufacturer of your gauges also likely makes a blank gauge assembly that will exactly match the other gauges if you are really picky.
BobGinCO
Once you have the Cable Hole Plug, cut it, and install a red toggle switch in it.
Label it "Missile Launch".
smokeonthewater
another option might be a RAM gimbal base of some sort if you have something that could be mounted in it such as a gps or vhf
Gauge Instruments are about that size. Do you need one?
OllieC
Ha!! Yes, I would "like" one and considered it, however I have a Garmin Chartplotter/Sounder that it would interfere with.:doh: I actually started a thread in the Electronics section about this this morning.
OllieC
Thanks UncleWillie. I googled, and looked today and all I could find were PVC end caps. I'll order them up!!!!
smokeonthewater
hmmm I wonder if there is a dash display that could network w your existing sonar
OllieC
^^^^"Ordered" ^^^^
OllieC
Kevin-Maybe...if my boat was the size of your Wellcraft:D - I have a really small dash. I couldn't even fit the Sony remote in place of the Clarion because the hole was an 1 1/4" larger. My Garmin is bracket mounted on top of the dash.
smokeonthewater
yeah my dash is small too after stuffing it full of two sets of gauges and a synchronizer... I was thinking of a small one that would fit in the existing hole.
