2 Homemade bellows tools
Rake722
I'd just like to share 2 tools I made at home to help install the bellows on the gen 2 OD
The exhaust tool had the bellows on in seconds with little issue.
Ayuh,...... I do exhaust tubes rather than bellows, but I Love yer tool design,......
For the locking ring, I squirt the bellows with Quick-silver Power Tune, 'n push it in with my fingers,.....
Rake722
Thanks Hall I have now had the opportunity to use the tools and can report that the exhaust bellows had the job done in 10 seconds the U joint bellows to was also very effective
dave tingue
hello all, i have a1986 mercruiser 3.7 i need to change the exhaust cooling hoses- nothing on Utube so i thought id ask here-how the hell is this done without too much PITA?
harringtondav
....You'll probably get more feedback if you start a new post on this. ...per forum protocol you should.
Always at least minor PITA, especially if they have been clamped for a long time. Hose pick, low temp like a hair dryer or heat gun set on low temp will soften the rubber.
If you are changing them,not saving them, destroy them. Remove the clamps, sawzall out the center, grub off the ends with a screwdriver.
