larrythorson
Thread starter- Joined
- Sep 25, 2015
- 13
I have a 1986 Celebrity 190 with a 305 Chevy with a OMC Cobra that has a total of 320 hours. It was 13 hours on a total rebuild the front seal either had pressure build up behind it, or seal failure dumping the gear lube into the bellow, dropped the case to where the oil was just covering 1/2 of the gears in the upper case. I removed the unit and returned it to Southern Michigan to the outfit who originally rebuilt it after I struck struck something with the OEM outdrive. They pulled it apart and "rebuilt" it and returned it after supposedly changing the upper vertical output shaft and the shims under the preloader and returned it to me. I again installed the unit and i had a total of 30 minutes run time 20 of which was at less than the spedo would register and never more than 1/2 throttle. I didnt see any initial problems and all seemed fine until I pulled the dipstick plug after returning home and found 1 drop of blackened Volvo Synthetic on the stick repeated again and nothing on the stick!!!!! Pulled gear case cap and again only half of the upper gear set was covered and the rest went out the seal into the bellow. I returned the unit as it is under warranty and the owner is now saying its because its overheating because there is a circulation problem with my fresh water open system. I removed the inlet to the cooler and ran my engine for 15 minutes and after about 5-7 minutes the temp came up to a rock steady 160*F and never went any higher and the water coming thru the transom was warm but tolereable to the touch. I then pushed water back out the transom thru the intake port and no obstructions anywhere. can someone please help me I am not a rich man and this was supposed to be for the family to enjoy and its turned into heartache for us
