southerncomfort1
Thread starter- Joined
- Sep 18, 2008
- 15
Bought this motor last fall (9.9 early 90's Johnson)and have 2 problems. First it runs great but smokes WAY more then it should especially at high ideal and does not stop.Almost like it would when starting it up after a good fogging but keeps going.After running I get the gray sludge stuff leaking out the exhaust.Tried leaning it with the knob on front of motor but just wanted to die if moved to much.Second problem is water is not draining from it completely.In order to drain completely you have to have it unmounted from boat and turn it over or should I say on it's side and as soon as you rotate it on it's side the water comes out the exhaust holes just under the head.When running has strong pee stream and water comes out exhaust holes when warmed up and running.Water drains out bottom drain hole near in front of prop when off and pulled from water.Like I said motor runs great but these things are not right.HELP...ANY IDEAS??????Are the 2 related????
