wake4me
Thread starter- Joined
- Jan 26, 2010
- 7
Hello. New here and think this is great! I have two questions to ask the experts of iboats forums on a Cabureted Volvo 5.7L 350 that sits in a 1998 Four Winns Horizon RX.
First, is it better to remove the thermostat from the engine or is it frowned upon? I would think that it would help to keep the engine from over heating?
Second, I have 4 water drains on the engine. Two on the block (1 ea side) and two on the exhaust manifolds (1 ea side). Can you remove the drain plugs, replace them with a 1/4" brass or plastic nipple, then with 3/8" vinly/plastic hose and "y's" or "t's" connect all 4 drains into one hose that could pass thru the hull to the exterior of the boat near the main water drain plug? I think it would be nice to drain all water from the engine every time I pull the boat out of the water.
To add to this second question... Could the thru hull drain be left open at all times or would it need to be plugged while in the water? I'm not sure if it were left open would allow too much water to by-pass the cooling system?
