I just had my lower unit rebuilt the other day and it is much better now. i put new oil in it and the first time i took it out, it shifted into forward and reverse so smoothly that I didn't even here a "thunk" into gear. yesterday i took it out again and I heard it "thunk" into forward and reverse. i was wondering if this is normal, or if i am getting water in the lower unit? we replaced all of the seals, so it should be water tight, but I am paranoid about this stuff.
also, how tight should the prop nut be? I didn't think it was supposed to be tight, so I just hand tightened it down and put the cotter pin through it, but I read on here that some prop nuts have to be really really tight. this is a 1973 evinrude 50 hp engine.
thanks you all!
thanks you all!
