Re: 2 roller or not 2 roller that is the question
Roller cams allow for less friction and higher RPMs as a result. However, if the other internal parts don’t support the extra capabilities (like heads, valves, and exhaust removal), you may only see very little results. You have to understand that roller cams go very well with roller rockers and the list goes on and on. While the addition will reduce internal friction, that quite easily could be all you may see too... When building any engine, you have to decide exactly what you are shooting for and built to that design. Putting in just a roller cam with higher lift or duration capabilities could result in a more problematic engine without any increase of usable output, especially in a boat...
