Hi there, I have a 96 200 mariner efi, just had the water pump replaced, old one look fine but still replaced, and the tail tell pulsates when running, did this with old water pump. The water psi gauge jumps around from 5psi to 10psi. I had an over heat alarm the other day and shut it down for a while and started back up and the water coming out was rather warm. Should the tail tell pulse like this or is there something else going on.
My rpm guage is the other question, it reads fine one minute and then it starts to jump around to higher and lower rpm's the motor sounds fine and steady. Do I need another guage or is it something else? Thanks
