2 screws into mercarb rebuild and stuck -- stripped screw
sickwilly
I am two screws in and have messed up. I stripped the screws holding the choke housing. I have craftsman screwdrivers and dewalt tips for my other screw driver. Tip sure seemed to fit good, but the screw metal gave away before the screw turned.
Not a good omen for my first rebuild.
Now I guess I have 2 options:
Cut my looses and order a rebuilt online.
Drill it out and hope to find a similar size screw to replace it with.
Any advice would sure be appreciated.
kelscrusader
Re: 2 screws into mercarb rebuild and stuck -- stripped screw
Get a screw extractor set. Should be able to get them right out.
excalibur1031
A good tool for removing stubborn screws is an impact driver. It uses the strike force of a hammer to create a high torque motion combined with an impact to release the torque on a screw. You just have to be careful using it in order to keep from damaging parts. As far as the extraction, Grab-it screw extractors work like a charm. I believe Sears makes a set exactly like it. Finding a replacement screw is easy just bring one into an ACE hardware store or specialty fastner store and they can match one up to fit your needs!
sickwilly
OK, thanks, I got it out. I will have to get a replacement screw tomorrow. Rebuild back on track.
Right now I have parts soaking in carb cleaner. The carb cleaner dip says to rinse with water. I guess I will follow directions.
Silvertip
Honorary Supreme Mariner
Forget the impact driver. You are dealing with a carburetor which requires a little gentler technique unless you want to buy a new carb. Those are fairly small screws so unless you hit them dead center, drilling will most likely end up off-center. While you may get the screw out you may have a buggered up hole anyway. No simple solutions here.
smarks
So tell us, how did you get the screw out. Don't leave me hangin :confused:
Steve
MahtyMaht
I like the hand Impact, but on small screws in pot metal, a feel is required - If you haven't torqued and trashed some of these things to death before, then your hands don't know when to quit. Me - I never saw a screw extractor that consistently worked before. Ever. I like to cut right to the chase. I let the phillips slots center the TAP drill. You'll feel it when the drill drops thru the end of the dead screw. Then I run a tap in there, and clean up the screw's threads. Longest way round is the surest way home. I never lose with this. Glad you got yours out.
sickwilly
I drilled a pilot hole and used a screw extractor in my drill. Once the initial hold was broken, the screws came out super easily.
I guess its a matter of the right tool, but I don't understand why those screws, which just hold the choke housing on, were torqued in there so strongly. Both are ruined.
I am off to Ace hardware today to try to find a suitable screw.
6meter
Wash everything with water then blow dry everything with an air compressor. Be sure all the little holes get blown out.
