fullquartpress
- Joined
- Jun 17, 2013
- 6
2 tries to run from a fuel line with the 8hp's leg immersed in a barrel of water resulted in no known firing.
Next day after try 1, and with the choke knob in, and not on 'fast idle', and without water, it fired and ran for a second.
After try 2 with fuel line connected and with its leg in water, and no known firing, I removed the plugs, which looked OK, and pulled the starter several times, then reinstalled the plugs, torqued to 20 footxpounds.
Next day, tried to repeat the dry firing, but couldn't...until ~3 milliliters of fuel from a squeeze bottle through the 1/2 inch hole in front of the carburetor made it run for a couple of seconds, without the leg in water.
Is removing the carburetor the next step, or should I try reconnecting the fuel line, with the leg in water, and try the squirt of fuel through the butterfly again?
(I have a 'manual', bought online, indicating that the carburetor is a Walbro WM with single float, and with instructions for cleaning and rebuilding the Walbro WM, but no apparent 'troubleshooting' for the results I've had so far).
Thanks again for your advice.
