2 stroke oil reserve tank over filling with fuel ???
No more boats
2000 OX 66 =250 hp - 2 stroke
yesterday , pulled boat , pulled drain plug
water coming out was clear , then oil was mixing with the water with a smell of gas coming out ?
Never had a problem with 2 stroke oil system
gas is returning & over filling 2 stroke external reservoir . ( reason for oil/ fuel in bilge ) tank was overfilled with oil & fuel coming from top and where tank is mounted it runs off into bilge
Engine oil tank had gas mixing also
Making a complete loop of the oil system
realize i can run 50 :1 oil mixture by passing but want everything working as it should
what would cause the fuel too come back too oil reserve then fill engine oil tank ?
oil pump ?
inside vst tank ? stuck float
check valve ?
this issue must have happened on return too port cause hour earlier my head was in bilge and everything was fine , I was off shore close too port
some thoughts is appreciated
99yam40
I have no idea how gas could be transfered to the oil system in an injected motor
No more boats
I agree with you ,
I have a retired marine mechanic buddy , he looked at it yesterday ,
He said this is a first ,
He feels its the check valve causing back flow ???
He said if you cant fix it , just by pass and run 50:1 directly , as a last resort but want it running as it should
lelyyy
It’s true—check valves tend to get stuck when they’re old. Might as well try swapping it out first; they’re not that pricey anyway.
I agree with you ,
No more boats
2000
OX 66
2 stroke
250 HP
After a day on water removed drain plug , Smelt gas
Puddle of oil * gas, bilge ?
Axillary tank over filled with gas and traveled into bilge , ?
Opening reserve oil tank had a gas smell
Same with oil tank on engine
Months prior new Carter fuel pump in VST tank, filter , gasket .
Ran boat many times with no issue
This all happened weeks ago , started too find out WHY but had too go out of town Back on it now
Noticed ( don't know why ? ) put the black vent line from oil tank on one of the small nipples top of vst ??
Could have this caused no release and fuel too back up with no vent ??
As I said engine Ran fine many times . That day Temp was around 95 ,
Float got stuck ??
Check valve by oil pump ??
Thinking about adding two check valves at top of VST top , one for Oil & fuel
Any other ideas before I get back too fining out how this could happen ??
thanks
No more boats
2000
OX 66
2 stroke
250 HP
Float got stuck ??
thanks
Just noticed a few responded from my last post , sorry I reposted , going too swap out check valves and make sure float is not stuck ,
No more boats
Follow up , Fixed , Fuel got into oil tank cause of two issues , Oil check valve was ng , Needle in vst tank was not sitting correctly causing fuel too over fill , Since check valve was ng fuel had no place too go but back flow into oil system , When reserve tank filled it dumped into bilge , Took it out yesterday , all is good ,
