Re: 2 stroke vs. 4 stroke
Hi,<br />Can You tell us what a "sky boat" is? (Make and model)<br /><br />A 4-stroke is not necessarily more expensive than 2-strokes. Many new 2-strokes with Direct Fuel Injection (DFI) are also expensive. Evinrude E-tech, Tohatsu TLDI, Mercury Optimax, Yamaha HPDI for example.<br /><br />Since I do not know what type of boat You have (seize, weight, planing boat or not etc) it is very difficult to give any advice.<br /><br />If You plan to do much maintenance Yourself it is probably wise to select a 2-stroke with carburators.<br />If You plan to let a marine service center do most of the maintenance make sure it has a good reputation and in vicinity where You live. It wil be easier if any trouble, warranty and the service itself if You do not need to travel so long to have things fixed.<br /><br />I had 2-stroke before and I have a 4-stroke today. It was about 10 year between the two outboards and although 2-stroke technology has advanced since then I just like the 4-stroke very much (Electronic Fuel Injection - EFI, instant start, very quiet, fuel efficient, silent, no smoke and gas smell). Older 2-strokes just can not achieve all this. Newer 2-trokes can but then it will be almost as expensive as a 4-stroke. <br />I use a Yamaha F115 4-stroke (2003) and I like it alot. It has been on the market since 1999 and obviously has no problem anymore with such things that can be problem at introduction of a new model. In 2004 it became CARB 3-star rated (was 2-star before). It is one of the most proven 4-strokes in this seize together with Honda BF115 4-stroke that probably has been longer on the market.<br />If You are in the market for a 115 hp outboard and You have the money a Yamaha F115 is a good choice. Other makes produce also fine outboards like Mercury, Honda, Suzuki, Johnson etc. I'm just happy with my F115, that's all.<br /><br />Good luck!
