2 wire tilt and trim ?
Gartanic
Hello I have a 1980 evinrude 70 h.p. I just put tilt and trim on (wich it never had before) and it only has 2 wires out of the trim motor (blue & green). I've never had a 2 wire set up before but noticed that i have to reverse the wires on from positive to neg. to move the motor up and down. Do I need relays or selinoid to make this work with the trim switch? By the way my trim switch now has 3 wires up/down and a power wire ,is this the right trim switch? Any help would be great!:)
thanks
Joe Reeves
Re: 2 wire tilt and trim ?
You'll need the dual relay setup with the two wire electric PTT motor.
You have the correct trim switch.
Gartanic
thank you Joe I'll get on it and see if I can get it going.
thanks for the help!!
christian
Andy in NY
i think my new to me '70 85 hp evinrude has the same thing... has 2 wires green and blue coming from the trim pump, but no switch came with the motor.
what exactly do i need to make it work?
