hawgherder
Thread starter- Joined
- Feb 23, 2008
- 5
I have a 1993 200 efi that will not accelerate beyond idle. I have checked the fuel system and found that the fuel pressure is 90 PSI ( should be 30-39 PSI)at the test port above the high pressure fuel pump. I know the fuel pressure regulator can cause this but it seems to be clear of debris( not stopped up). Can high pressure fuel cause this type of problem? I have checked the ignition system and the throttle position switch and it is good.
