Oldcraneguy
- Joined
- Jan 30, 2013
- 27
I just acquired a 88 Ranger with a 98 200EFI that hasnt run in 10 yrs I moved the flywheel a cpl inches with my thumb so I know its not froze Im just curious what I should do before trying to fire it? Id like to pull the injectors and try to clean them up and flush the fuel lines and rails and Im wondering if I get the injectors/rails off and turn on the key will the supply pump run? if so will it run long enough to clear the lines/filters or will it shut off after a cpl seconds like a car? also is there any reason to worry about 10 yr old oil in the tank? (its full) any suggestions appreciated....OCG
