I have a 89 200hp that is not getting spark to the plug on the bottom cylinder . I tried switching a coil that know is good and still no spark. I switched the wire coming from the power pack to another coil and then that spark plug would not spark. Would that mean that its the power pack? Could it be the stator? The motor will start and idle but when you give it throttle it will either die out or you have to go to WOT three or four times then it will take off. I am puzzled I don't have the money to take it somewhere so hopefully I can fix it myself.
