200 HP yamaha 2 stroke- fuel bulb won't prime
captaincayman
lost power all of sudden, motor started but won't stay running. checked fuel bulb and was soft but would not prime. took cowling off and found clear fuel filter 3/4 full which it should be full. please help with any suggestions?
99yam40
out of gas in tank or air leak where the fuel cannot be sucked from tank
Silvertip
Honorary Supreme Mariner
fuel filters don't always need to be 100% full and rarely are. How they are positioned has a bearing on this but again, I've owned lots of outboards and rarely is the filter ever 100% full. Fuel bulbs can go soft after the engine starts because fuel is being sucked through them, So two out of two symptoms don't point to the source of the problem. Lack of fuel pressure (such as a weak or bad pump) may be. Try a different portable tank to eliminate the current tank as the problem. Do the cheap stuff first -- like check the plugs, spark on all cylinders, spay a fuel oil mix into the carbs and see if it stays running. If so you confirmed a fuel issue. If not, look elsewhere.
Barnacle_Bill
Check the fuel line and primer bulb too. Both should be soft and pliable with no cracks.
Watermann
Sounds to me like the valve at the tank where the supply line attaches is letting the fuel drain back into the tank leaving the bulb flaccid.
pete j
Ive got to bing or google flaccid never herd that word before, but if somebody knows Id like to know
