200 johnson compression?
ncfisherman
what should the compersson be on a 98 200 johnson venom be? And what is a low compression number?
tashasdaddy
Re: 200 johnson compression?
all guages read differently, the reason for no published recommended pressure. 200 hp 90 psi, the main thing is that all the readings are with in 10% of each other.
