Looking at a boat with a 200 ocean pro and the motor hasn't been run for a while. When they did a compression test by jumpin the starter because the switch key is gone they could get 90lbs on one side and a 90,65,70 on the other side. I was wondering if this would change if I lubed the cylinders with some WD40 or something like that. or would you think this just needs to be rebuilt with compression like that. Any help would be appreciated thanks...
