joepauljig
Thread starter- Joined
- May 20, 2007
- 9
Hello,
I've got a 1990 200 HP Johnson GT that I can't figure out. Starting last year it developed this idle problem. When I start the motor, it will run a few seconds at idle and then die. It sounds as though it's loading up on fuel and then dies. I'm no mechanic so I'm not for sure if that's what it is doing or not. It doesn't "cough" and "spit" as some have described. It just dies after a few seconds. I can start it and then immediately push on the throttle and sometimes overcome the stall and then once I get it on plane, it runs fine. Then we start the process all over again when I'm ready to start it up again. It just won't idle. I had the carbuerators cleaned and adjusted about 2 years ago and I have used the boat heavily during the spring, summer, and fall months.
I've read through the forums and not sure where to start. I don't know if adjusting the timing knob will help or if there is something else I should start with.
Any help or suggestions would be greatly appreciated.
