2000 200 hp FICHT EMM software connection port
mikel2k
I can't seem to find the plug for the pc connector for my 2000 FICHT engine can someone help me out and tell me or sent pics of its location! Thanks
Haffiman
Re: 2000 200 hp FICHT EMM software connection port
Triangular 3-pin plugs on stb side. Was from factory equipped with a protecting cap that might be gone. Only 3-pin except for the one to the trim switch on lower cover if not mistaken.
fireman_bob
On my 2000 200hp it's on the stb side up near the emm. There are 2 connectors (male+female) joined so you'll need to unplug them from each other. One connector has 3 wires, the other has only 1, a black one back to ground. Once you separate them, your PC plugs into the one with the 3 wires.
droach77
^^ditto my 1999 90 has the same plug setup, the cap has a black wire. Kind of confusing because no diagrams show it like that.
dave
