- Joined
- Mar 8, 2009
- 44,669
It's the ECM relay drive circuit
Can give this guy a call to see if he can/will
https://obd2allinone.com/ecmrepair.asp
Yes, but only for a couple seconds when key is first turned ON. Once ECM removes the ground you will see 12V againPin 30 85 and 86 have 12v with the key on for the fp relay….. shouldn’t pin 86 be the negative from the ecm?
Take a light bulb and put 12V on one side leave the other side disconnected. Put the negative meter probe on the negative battery post.Can u explain how or why pin 86 shows 12v?
So when key is first turned ON you should see zero volts on 86 until the ECM removes the ground. If it stays 12V full time then either no ground is being applied or there is a bad connection.I’m unclear about pin 86….
I’m running an aligator clip from the negative batt terminal to the neg of my volt meter.
There is no ground being applied by the ECM "or" there is a break in the wire.Ok I’m reading 12.35v. With the key off. When my boy turns the key to the run position it reads 12.26v.
Did you ever get this resolved? I'm having an identical issue and getting the oil pressure code.Ran out of time today. I’ll take a look in the am and report back. Thanks again for your help dodge
