Learned alot on this forum, and now have a problem of my own. Motor was laid up for 3 years, but not properly. By that, not run dry, or fogged. Not by me mind you. Know better. Had carb rebuilt, new plugs, impeller, decarbed, gone over by Yammie tech. Ran great on 3 different occasions for about an hour each. Its on a Sears 12' tinnie. Fourth time out, was surging a bit at 3/4 throttle, went to idle and it stalls out. Primer ball good, tank vent open, no overheat . When I disconnect fuel line from engine, does seem to be under alot of pressure. A little fuel shoots out. Reconnect, and pull on it til arm ready to fall out of socket. Paddle to shore. Next day, check under the cowl fuel filter - fine. Blow out all lines from carb back to tank, through the primer bulb - seems fine. 1st pull starts up, and idles fine. Let it run 10 - 15 min. in neutral a bit above idle, and then it stalls and won't start again. Next day, give it a few pulls and it starts. Again, let it idle in neutral for about 10 - 15 min., put it in gear at the dock with it tied up at idle speed - fine. Under a little load - fine. I'm ready for a ride down the river. Takes about another 10 min. to load up saftey/fishin' gear, put it in gear - STALLS. Won't restart. HELP!!! My oil mix is 75:1 vs. the 100:1 it calls for.
