Mischief Managed
Thread starter- Joined
- Dec 6, 2005
- 1,928
I did a leak down test for fun (engine was running fine, I was just curious). There were times when I didn't quite have the piston in a cylinder under test at TDC and the pressure form the tester pushed the motor over backwards a few degrees. I didn't think anything of it.
When I was done, I fired it up and the engine rattled for a couple of seconds as though the lifters had bled down. It has never done that before. Also, I hear a light ticking now that I don't recall hearing before. It sounds like excessive valve lash on one valve. Could I have damaged anything by letting the motor turn backwards a little? It's a Generation VI, so it has roller lifters.
