flatsider45
Thread starter- Joined
- Jun 10, 2010
- 72
I have a completly new fuel system,tank clean,all new hoses,primer bulb ,water seperator,carbs gone through,new cdi pack,new plugs.Cranks fine every time,will idle in gear until you start to put the fuel to it and thens boggs down.Can feather it under way at the carb linkage and get it to move a little better for a minute or three then all of a sudden it will snap out of it and run wot with no problem.Bring it back to idle and take off with no problem.Let it sit for a while say fishing a spot for an hour or two and go to move and it may take off just fine or not.Have to go back to the throttle linkage to get it to move at a little better speed and bam it takes off again just fine.motor has 135 lbs compression flat across all three cylinders.It's almost like you snap a switch when this happens.It is a systems check motor. No buzzers,no warnings no nothing,just does and then dont .Any ideas?
