Roberthill
Thread starter- Joined
- Dec 3, 2012
- 317
Model J90VLSSS . Can not get it to idle . Using primer can manage after a couple of times to get it running at WOT runs good at this point but when slowed down it dies . Here is what I'v did so far . I can get it to halfway idle using primer then throwing in gear and taking off .
1. Took all carburetors off and made sure they were clean .
2. Changed in line filter and cleaned filter at fuel pump.
3. Checked compression . 100 PSI (if loaner from Auto Zone was right)all cylinders.
4. Spark checked good jumped about 7/16 of an inch.
5. Took idling jets out and checked they were clear .
6. Fuel pump is pumping ,did the pump bulb thing .
I don't give up easy but I do give out , Can someone give me some direction ?
