2000 Cruisers 2870 Check Engine light blinking but no codes?
CLi87
The check engine light on the console starts slow blinking steadily immediately after starting the engine but when I checked the codes in my Mercruiser 7.4 MPI it just gives me code 12 which should mean system is operational and nothing is wrong? Any idea where I should check to get the check engine light to stop blinking so that when something really is wrong then it'll blink
dingbat
In some older GM-based diagnostics, Code 12 can refer to a distributor signal interrupt, but on modern MerCruiser MPI systems with smart alarms, it is almost always related to the drive lube monitor
CLi87
My drive lube level is fine so I'm guessing it's not that, what would cause a distributor signal interrupt?
dingbat
Just because the level appears to be correct, doesn’t mean the circuit is functioning properly. Floats get hung up, rodents chew on wires
Never guess …always test
CLi87
Just made it out to the boat, so I tested the oil pressure sensor, temp sensor and drive lube sensor by unplugging then to see if any shut off the check engine light but it just kept flashing, also to note with key on engine off the check engine light would flash 2 times and then stop, but then once I start the engine it just constantly slow flashes.
Should be an MEFI ECM. you have to jump the pins to put it in diagnostic mode and read the flashes. you will need to get the VP MEFI manual (should be similar to other marine MEFI setups)
