2000 Escalade brake light
bruceb58
Re: 2000 Escalade brake light
Thermostat is probably your issue. Either that or the sender wasn't grounding properly.
sphelps
You all got it right ! The t-stat was stuck open . Put in a new one and motor running at around 185-200 at dash gauge . ;)
This sight but mostly you guys are the absolute best !!
Thanks for all the help ! SP...
sphelps
Hopefully nothing ! :pray2:
But I,m sure something will pop up .. :facepalm:
dingbat
Rule number 1..when troubleshooting. Check the obvious first.
Rule number 2....never use an IR gun to take readings inside a thermal mass.
Rule number 3 .....double check rule number 1 ....lol
Glad you figured it out
