2000 Honda 8HP Exhaust leak repair
Pontoon24
I have what appears to be an exhaust leak on my motor. It bogs down when in the water. On the test stand if I keep the exhaust ports dry and the engine cover off it runs fine.
I'm considering repairing it myself and need help getting through it. If I go at it without help I'm sure I'll disconnect more parts than I need to.
The parts in question appear to me to be #6, 7, 8, 9, and 10 in this diagram.
http://www.boats.net/parts/search/H...AS-1599999/OIL CASE + ENGINE COVER/parts.html
Any help would be greatly appreciated.
Thanks, Andy
Pontoon24
Re: 2000 Honda 8HP Exhaust leak repair
OK, no help yet.
I took it out for a test and thought you might get a kick out of this. I removed the handel part of the engine cover and made a air sccop to push fresh air down into the engine. And yes, the top end problem was gone
I probably have not been specific enough with my question. I don't need a step by step explanation of what to do, really, just which bolt to start with. Do I start right where the engine and shaft extension come together or farther down the shaft extension as if I was changing a water pump? Really, all I need is a starting point. Anyone?
Andy
gus-gus
Well? What did you end up doing?
I just found an exhaust leak on my 1988 Honda 8 HP outboard. Mine is the same issue exactly. I filled the exhaust well up with water to see the bubbling leak and knew the trouble quickly. Now I am looking for parts!
